Group: DynoMotion Message: 6672 From: jing_usc Date: 2/5/2013
Subject: Opto input from Kstep with 12V power supply
Can anyone help me to see why my kstep opto inputs do not work.
I connect the pin 8 of JP33 to 12V power supply(the same one for kflop power supply), and then short pins (eg. pin 9 Opto IN 0) to GND (pin26). Then I used console to 'readbit 168', the value is always 0 regardless of the pin8's voltage.
Group: DynoMotion Message: 6673 From: Tom Kerekes Date: 2/6/2013
Subject: Re: Opto input from Kstep with 12V power supply
A line of C code needs to be executed to tell KFLOP that KSTEP is present so it will multiplex in all the inputs.  Add:
KStepPresent=TRUE;
to a C program.  Have you done this?
See Digital Status :
http://www.dynomotion.com/Help/SchematicsKStep/UsingKStep.htm
Group: DynoMotion Message: 6674 From: Jing Zhang Date: 2/6/2013
Hi, TK,
I did not add that line. So the states from (168~183) in virtual/kstep of digital I/O can not be chosen before the line is added, right?
How could I add that line just in kmotion, either in console or C program? I am using kmotion/kflop version 4.28.
Best
Jing
Group: DynoMotion Message: 6675 From: Tom Kerekes Date: 2/6/2013
Hi Jing,
Yes you must execute that line in a C program.  The example InitKStep3Axis.c already has it.
or you can make a 1 line program like this:
int main()
KStepPresent=TRUE;      // enable KSTEP input multiplexing
Please use a more up to date Version.  Preferably our Test Version:
 http://dynomotion.com/Software/KMotion430j.exe
Group: DynoMotion Message: 6676 From: Jing Zhang Date: 2/6/2013
Hi, Tom,
I am trying it now.
I will let you know the result.
Best
Jing
Group: DynoMotion Message: 6677 From: Jing Zhang Date: 2/6/2013
Hi,  Tom,
I updated my kmotion to version4.30j, while in my program, there appeared some error during compiling, ''CKMotionDLL::WriteLine' : function does not take 2 arguments."
I noticed there are some change in the new CoordinateMotion class. The previous 'int m_board;' disappears in the new version, and there are less argument for writeline (without m_board), so how do you decide which board to choose?
Could you please send me some examples in C++ regarding the change?
Best
Jing
Group: DynoMotion Message: 6678 From: Tom Kerekes Date: 2/6/2013
Hi Jing,
Yes sorry that was changed to make things more object oriented.  The board is now specified when the CKMotionDLL object is created.
There are a number of C++ examples included in the download.  See the SimpleConsole.cpp file.
Group: DynoMotion Message: 6680 From: Jing Zhang Date: 2/6/2013
Hi, Tom,
The opto inputs on kstep worked finally. The kmotion I am using is newest version now.
Thanks.
Best
Jing
Group: DynoMotion Message: 6711 From: Jing Zhang Date: 2/12/2013
Hi, Tom,
I want to integrate this opto input function in my own program.
I do not see any structure that contains KStepPresent, you know how I could do this?
Best
Jing
Group: DynoMotion Message: 6712 From: Tom Kerekes Date: 2/12/2013
Jing,
You would need to have your program Compile Download Execute a C program.
See the SimpleFormsCS example.
